It is currently Sun Apr 12, 2026 8:29 pm
[ 2 posts ] |
bojac
 driveshaft tube length?
If I mod a longtail driveshaft housing by adding an upper and lower bearing housing kit it might shorten the driveshaft housing some. I will have to cut off the thin part on each end of the housing where it was machined for bushings and seals to have enough good metal to weld the slip on bearing housings. Is there a Hoyle's rule for housing to driveshaft length, or will I be ok? I will have to cut 3 3/8" off of each end. The bearing housings will give back some of the length but I don't know how much. Driveshaft is 6' Whatcha think?
| Mon Jul 07, 2014 8:08 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: driveshaft tube length?
Sounds like you got it under control, just be sure to maintain the original length to allow the machined part of the shaft to work for each end. Id cut one side first, tack, measure down and mark, cut, tack, take a final measurement to be sure the length is the same as original, and weld...
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Tue Jul 08, 2014 6:59 am |
[ 2 posts ] |
