It is currently Sat Apr 11, 2026 10:12 pm
Reply to topic  [ 7 posts ]
 Go Devil Long Tail Mechanic in East Texas
Post Go Devil Long Tail Mechanic in East Texas
I apologize if this has already come up, I tried a search and couldn't find anything. Do y'all know of anyone in the East Texas area with experience working on go devil long tails? I'm having issues with my starter and my shaft won't hold grease so I'm assuming the seals need to be replaced. My mechanical prowess is pretty dismal, unless it's something super easy or that I've done several times I tend to make things worse. I'm in Nacogdoches, thanks so much!
Tue Jul 15, 2014 12:39 pm
Post Re: Go Devil Long Tail Mechanic in East Texas
leanord, I don't even know you but both problems you mentioned I'm sure you can fix. Just call go devil and get the manual for the seal change. Starter is as simple as unbolting and take to alternator, starter shop to get tested.
Tue Jul 15, 2014 6:16 pm
Well...
Heritage Marine in Beaumont does fine work on GD LT and SD - they
took good care of me on my GDSD recently - fine folks...
Kresta Marine has several locations and good mechanics too...
Eat - Sleep - Hunt ! ! !
Tue Jul 15, 2014 10:04 pm
Will carter is right outside of longview pm for info does excellent work
4500 black death with a little more in it strapped to a 1848 wc custom
Tue Jul 15, 2014 11:42 pm
Thanks so much for the responses. I'll look into these suggestions and let y'all know how it works out.
Thu Jul 17, 2014 12:04 pm
