| Fuel line and tank for 23 hp vanguard http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=55890 |
| Author: | bluesky2012 [ Tue Aug 19, 2014 6:59 pm ] |
| Post subject: | Fuel line and tank for 23 hp vanguard |
Putting a 23 hp mud buddy on my boat. I need a fuel tank, line, etc and am debating putting it in the front of the boat rather than the back to help the boat plane out. A few questions, what fuel line should I get since i don't think it's the same as a regular outboard (didn't think to look) and has a different connection to the engine. I assume to squeeze ball on the line? Is there a difference in flow quality over a greater distance (4 ft vs 14 ft?) Any other help is appreciated. |
| Author: | Glades Ranger [ Wed Aug 20, 2014 4:46 am ] |
| Post subject: | Re: Fuel line and tank for 23 hp vanguard |
Generally, for most applications, a 1/4" internal diameter fuel line is best. I am not familiar with the 23 Briggs. My 18 Briggs, 25/27 Kohlers, all had the mechanical fuel pumps and no bulb was required but I never placed the gas tank in the front. I chose to put my full-size battery up front for weight distribution (plus toolbox and other items) and with a battery and longer run you would need a heavier gauge wire...if your motor is equipped with an electrical fuel pump, a longer run like your 14' one might be compromised and you may need a squeeze bulb. My friend had a 24 Honda some years ago (that was a real lemon) and he had problems with fuel rate from his electric pump from the get-go. He had a squeeze bulb on his and that saved him a couple of trips when his electric pump failed and he putted back to the ramp. I wish I could help more, but I am sure somebody here has done it with their 23 Briggs (both a longtail or surface drive), and hopefully they will pipe up! Have patience. For me, moving the battery was easier/better, since I also have a bow mount trolling motor, and I thought shielded battery cables might be safer as well to run along the sides of the hull rather than a fuel line below the floor. Here in Florida, with the heat and humidity, I notice the fuel line deteriorates in a few seasons, so I replace it (along with the one to the carb and the section above the fuel filter) regularly. This would be more of a chore if I have to remove the flooring but I guess it can be "fished" out easily if the run is clean and free of obstructions, sorry for the rambling but that is the way of it, and sometimes trial and error is the only way. Let us know how it goes! Try the search function here! |
| Author: | mud slinger 69 [ Wed Aug 20, 2014 5:21 am ] |
I've got my tank up front on my 23 never had a problems with it. Stock motor I do have the bulb in the back by the motor. Get good fuel line make sure all connections are tight and roll with it. |
| Author: | tobydawg [ Thu Aug 21, 2014 2:03 pm ] |
My tank is up front on mine...stock 23 as well, primer bulb up front. I have 3/8" ID line from the tank up to the the inline fuel filter at the engine then 1/4" to the pump. No problems with it. |
| Author: | bluesky2012 [ Thu Aug 21, 2014 4:08 pm ] |
Ok sounds good. I'm gonna get it rigged up and take it out next weekend for the first run. Any good tips on what to do to get it tuned up and running well? Figure I'll change out the spark plugs, clean the carb, oil change. Any longtail specific tips to tune it up? |
| Author: | Glades Ranger [ Fri Aug 22, 2014 4:42 am ] |
bluesky, if you don't have a Tiny Tach, get one. This is necessary to make sure you are running right at idle, top end, under load, etc. I got mine direct and saved some $, the LT mfg.'s generally charge a few $ more. I got rid of the foam "pre-breather" around the air filter on my 27 Kohler, the carb now breathes better, after all, we are not cutting grass in the marsh except in the water. |
