It is currently Mon Apr 06, 2026 1:00 pm
Reply to topic  [ 5 posts ]
 Prop depth adjustment knob issue
Post Prop depth adjustment knob issue
The vertical travel adjustment on my 24 hp Honda beavertail longtail (the thing that screws in or out that adjusts how far down the shaft/prop can go in the water) tends to work itself loose during normal operation when there isn’t pressure on it. What can I do to keep it from working itself loose so that I don’t lose it? Thread tape? Thanks for any help.
1644 Go-Devil
2008 23 GDSD
Mon Oct 26, 2009 10:24 am
Post Re: Prop depth adjustment knob issue
what i did with mine is skrew it all the way out and find a nut that will skrew on your stopper, then when you get your stopper where you want it you can run that nut down tight and that will hold it tight
1542 Landau w/ 20 hp BT Longtail
custom dual exaust
"Hatchie Bottom" paint job
Mon Oct 26, 2009 6:57 pm
I thought about that after I posted this topic. That is exactly what I am going to do. Did you use a lock washer or just a nut?
1644 Go-Devil
2008 23 GDSD
Tue Oct 27, 2009 6:52 am
just a nut
custom dual exaust
Tue Oct 27, 2009 4:29 pm
Why not run the nut all the way to the nob then put a sping on it to hold tension against it?
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Sat Oct 31, 2009 12:20 am
