Prop depth adjustment knob issue
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=5651
Author:  duckbill [ Mon Oct 26, 2009 10:24 am ]
Post subject:  Prop depth adjustment knob issue
The vertical travel adjustment on my 24 hp Honda beavertail longtail (the thing that screws in or out that adjusts how far down the shaft/prop can go in the water) tends to work itself loose during normal operation when there isn’t pressure on it. What can I do to keep it from working itself loose so that I don’t lose it? Thread tape? Thanks for any help.
Author:  hatchie rat [ Mon Oct 26, 2009 6:57 pm ]
Post subject:  Re: Prop depth adjustment knob issue
what i did with mine is skrew it all the way out and find a nut that will skrew on your stopper, then when you get your stopper where you want it you can run that nut down tight and that will hold it tight
Author:  duckbill [ Tue Oct 27, 2009 6:52 am ]
I thought about that after I posted this topic. That is exactly what I am going to do. Did you use a lock washer or just a nut?
Author:  hatchie rat [ Tue Oct 27, 2009 4:29 pm ]
just a nut
Author:  LaBirdman [ Sat Oct 31, 2009 12:20 am ]
Why not run the nut all the way to the nob then put a sping on it to hold tension against it?
