It is currently Sun Oct 11, 2026 10:01 am
Reply to topic  [ 15 posts ]
 longtail on canoe
Post longtail on canoe
I am wanting to get a small longtail for my 18' flatback canoe and was wondering if anyone has any suggestions on a good kit, motor, size and tips on running a mud motor in a canoe. i have a big boat with a surface drive and i just need something to run my river when its way low
Tue Dec 30, 2014 10:47 am
Post Re: longtail on canoe
Kinda sounds sketchy , but it's your call. If your interested check out the glider kits from backwater. , you could use a small hp motor .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Tue Dec 30, 2014 10:53 am
This is probably the only time I wouldn't recommend a backwater motor...
Get a light 5hp-7hp with an aluminum frame. Weight is gonna be bad news on that canoe.
Tue Dec 30, 2014 11:00 am
Unless your canoe is 4' wide at the stern do not attempt! You will roll it over on a slow turn. If your canoe is shaped like a gheenoe then you will be fine.
Wed Dec 31, 2014 5:47 am
You'll be fine if its like a grumman workhorse fallback canoe. We had a guy put a 7hp on his and was getting 15mph out of it. But that canoe is a "trapper" style canoe rated for 1000lbs. so it drafted very little. This guy was no small fella to say the least, he was topping 350-400lbs. He used it for setting fishing jugs, just don't get aggressive with it in the turns and keep it balance on weight. You should be fine as long as you practice with it and wear your life vest.
Wed Dec 31, 2014 9:49 am
My friend has a ppf on his Grumman sport boat and it works very well.
Wed Dec 31, 2014 10:43 am
I have a Grumman with a 13 horse go devil.
Wed Dec 31, 2014 11:12 am
The fastest I've been was 14 mph. Had to put a fiberglass pod on the back.
Wed Dec 31, 2014 11:14 am
well I guess I will go ahead and try a 6.5hp. I have built a few bigger rigs for my medium sized boats but just wanted a feel for who has ran a mm on a canoe. sounds like my canoe might be a little small but we shall see if I flip it more times then not ha
Wed Dec 31, 2014 2:20 pm
17*38 Klibert 23GDLT
Wed Dec 31, 2014 3:07 pm
I have put 62 lb. 7 HP motors on the back of square back canoes,
successfully, for customers before.
Mark F. Cheney
on the Great Salt Lake marsh
Fri Jan 02, 2015 7:27 am
As said above it depends on motor weight, ttransom width and hull shape. I run a 6.5 hp Go-Devil, 109lb., on a 15'4" Gheenoe hi-sider and it is stable. However if it was a round-bottomed typical canoe hull I would not go above 60lb, maybe just a very light MM.
6.5 HP GDLT/ 12' Springbok or 15'4" Gheenoe or TDB Classic 14'
Fri Jan 02, 2015 7:57 am
Fri Mar 06, 2015 2:05 am
Lawn man:
What size is your Grumman?
Mon Apr 22, 2019 5:23 pm
That little rig looks like it could go anywhere
Mon Apr 22, 2019 10:25 pm
