It is currently Thu Mar 19, 2026 11:45 pm
[ 4 posts ] |
13 hp backwater bogging down
TFWaterfowlSAV
Any help would be awesome.
Once I drop the cav plate down below surface the motor sounds like it's bogging down and stalls out or "dies". Not sure if the predator has a low oil sensor but I am going to test that out tomorrow after reading some similar threads. Specs are below.
Predator 420cc 13-14hp depending on where you read the hp stats Backwater swomp lite glider kit w, 9x5 prop 15x38 flat bottom lite boat about 250ish Cav plate seems to ride fine right at surface.
| Sun Mar 08, 2015 8:32 pm |
ajverret
Joined: Sun Sep 29, 2013 5:33 pm Posts: 645 Location: New Iberia, La
 Re: 13 hp backwater bogging down
Check ur grounding wire
_________________ 1848 Uncle J and 37 EFI GTR
| Mon Mar 09, 2015 5:29 pm |
Nddatv
Turn idle up a lil more. The weight on prop needs a lil more force behind it
| Mon Mar 30, 2015 8:42 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
I'll bet you it's the low oil sensor. Start the motor while on the trailer then lower the prop like you were in the water and see if it dies.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Mon Mar 30, 2015 9:52 pm |
[ 4 posts ] |
