super long tail
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=61018
Author:  richard nagon [ Mon Mar 30, 2015 8:40 am ]
Post subject:  super long tail
Does anybody have one. that could give a review on. ?
Author:  stu [ Mon Mar 30, 2015 10:57 am ]
Post subject:  Re: super long tail
PM 4rivers.
Author:  4rivers [ Tue Mar 31, 2015 12:10 pm ]
I have a SLT with 35 cdi on a Gator Trax 17x54 I LOVE this motor had it 3 seaons now around 70hrs no problems at all. The neutral is handy but the big diff vs other LT motors I have owned is the belt drive makes the motor perform like a short shaft with the benefits of a LT. I have several friends who now have the SLT 2 have the 45 black death motor even its easy to handle
Author:  Swamper01 [ Tue Mar 31, 2015 12:42 pm ]
Do they still make the super longtail?
Author:  huck Finn [ Tue Mar 31, 2015 1:47 pm ]
Super longtails are currently for sale . $5045 for 35 hp. 37 hp efi available additional $500 , 44hp Black Death available as well . Stock 35 run a 10x 9 wheel. .
H Finn
Author:  Glades Ranger [ Tue Mar 31, 2015 2:00 pm ]
4Rivers, good report. I asked a while back but I was curious about the belt drive- what adjustments are needed, if any, on the belt tension? Have you changed this belt out yet? Are parts readily available? 45 horses!! Holy Toledo! Does that mean you can run an 11" prop? Wonder what speeds that will achieve? What do currently get with the 35 cdi?? I am glad MB has not ended production and support on this motor.
Author:  Schmidty721 [ Tue Mar 31, 2015 2:11 pm ]
Are they running traditional "long tail" props that are larger, or mounting surface drive props on them?
I need to start thinking about prop choice for the predator chassis I just picked up.
Author:  LB200 [ Tue Mar 31, 2015 2:40 pm ]
Author:  Schmidty721 [ Tue Mar 31, 2015 4:07 pm ]
Author:  flint87 [ Tue Mar 31, 2015 4:15 pm ]
Author:  LB200 [ Tue Mar 31, 2015 5:57 pm ]
http://www.mudbuddy.com/forum/showthrea ... +tail+prop
Here is a little bit of discussion about them
Author:  Schmidty721 [ Wed Apr 01, 2015 6:58 am ]
Thanks guys!
Author:  50fps [ Wed Apr 01, 2015 10:02 am ]
I'd try a 10x8 and see where the rpms are at for a starting point, then go from there.
Author:  Putt putt [ Wed Apr 01, 2015 10:30 am ]
I would like to see what this motor would be like with trim and big blade. I fine it's hard to hold a long tail in the sweet spot as for as prop depth and one I drove did better running on the surface but was a beast to drive. I would want to drive it longer than 10 min, but I think power trim on this motor would do wonders
Author:  flint87 [ Wed Apr 01, 2015 11:04 am ]
Author:  50fps [ Thu Apr 02, 2015 8:56 am ]
Author:  4rivers [ Thu Apr 02, 2015 2:47 pm ]
speeds with me a 90 lb lab,9ft four rivers layout and lots of decoys 22-24mph according to GPS seems to vary. Belt still plenty tight have not had to tighten Boat Dr thought it would not need it near as much as my Short shaft. Much shorter belt
Author:  flint87 [ Thu Apr 02, 2015 4:07 pm ]
Author:  Putt putt [ Mon Apr 06, 2015 8:30 pm ]
What I mean is I had a 16 hp gd that would do better when it was cavitating, It was prolly homemade idk, but power trim neutral and a free floating handle would have made it the best motor ever
Author:  flint87 [ Tue Apr 07, 2015 9:52 am ]
