It is currently Mon Mar 30, 2026 8:01 am
Reply to topic  [ 5 posts ]
 Brake Lever
Post Brake Lever
Where can I find a Bike or Motorcycle brake lever able to be fitted to a Long Tail Handlebar of 1 1/8".?
Must regular bikes take 7/8"
Any help will be appreciated .
thanks
P.B.
Fri Apr 17, 2015 10:10 am
Post Re: Brake Lever
Ebay, I bought a HD clutch lever for my 1" Handle, I am sure you can find something for 1 1/8"
Fri Apr 17, 2015 12:55 pm
The largest bar diameter you will find on a motorcycle is 1".
If you can find a lever that has a nylon bushing between the mount and bar, you'll be close it 1-1/8" with the bushing removed
Fri Apr 17, 2015 1:10 pm
Is the ID of your handle 7/8"? If so, shove a piece of 1/2" pipe inside it. It will generally wedge inside because of the seam on the inside of your handle, then put the lever and grip on the 1/2" pipe because the OD is 7/8"
Good luck
Sun Apr 19, 2015 11:38 am
Found one that will fit at Ebay, thanks you all for your help.
P,B,
Sun Apr 19, 2015 7:51 pm
