| Brake Lever http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=61349 |
| Author: | leonides [ Fri Apr 17, 2015 10:10 am ] |
| Post subject: | Brake Lever |
Where can I find a Bike or Motorcycle brake lever able to be fitted to a Long Tail Handlebar of 1 1/8".? Must regular bikes take 7/8" Any help will be appreciated . thanks P.B. |
| Author: | Ptuck66 [ Fri Apr 17, 2015 12:55 pm ] |
| Post subject: | Re: Brake Lever |
Ebay, I bought a HD clutch lever for my 1" Handle, I am sure you can find something for 1 1/8" |
| Author: | Schmidty721 [ Fri Apr 17, 2015 1:10 pm ] |
The largest bar diameter you will find on a motorcycle is 1". If you can find a lever that has a nylon bushing between the mount and bar, you'll be close it 1-1/8" with the bushing removed |
| Author: | fireman1293 [ Sun Apr 19, 2015 11:38 am ] |
Is the ID of your handle 7/8"? If so, shove a piece of 1/2" pipe inside it. It will generally wedge inside because of the seam on the inside of your handle, then put the lever and grip on the 1/2" pipe because the OD is 7/8" Good luck |
| Author: | leonides [ Sun Apr 19, 2015 7:51 pm ] |
Found one that will fit at Ebay, thanks you all for your help. P,B, |
