It is currently Thu Mar 19, 2026 10:22 pm
Reply to topic  [ 1 post ]
 Beavertail 35 hp Parts
Post Beavertail 35 hp Parts
Anyone happen to know what size/model yoke this motor comes with? I damaged the upper bearing and the manufacturer welded the key to the aft yoke, so I couldn't break the weld to get the driveshaft out in order to replace the bearing. Ended up cutting the driveshaft and pulling the u-joint apart to get everything out. I don't want to buy a new u-joint assembly from Beavertail for $100 and haven't run to the tractor supply store to see what they have yet.
Since I'm replacing the upper bearing, driveshaft, yoke, and seals, I figured I'd see if anyone knows where to find these parts cheaper than direct from the manufacturer. A driveshaft from Beavertail is $150 but back water sells one for $100. I'm getting a new prop from them anyway so figured I'd buy their driveshaft as long as it will work.
Mon May 25, 2015 3:22 pm
