It is currently Fri Mar 20, 2026 12:59 am
Reply to topic  [ 12 posts ]
 Briggs 206cc bogging down
Post Briggs 206cc bogging down
I have a briggs 206cc motor.
5' shaft long tail - straight drive - no U-joint - runs smooth as silk it does have a Cav plate installed
I ran it on a very light 1432 - and it just boggs down. I initially bought a 7x4 hill prop - then changed to a 6.5x4 prop and it helped, but I still can't hit higher RPMS
it will run 7- maybe 8 MPH with me and my 90lb lab up front - and that is a guess.
motor is completely stock.
any input ??
Mon May 18, 2015 7:15 am
Post Re: Briggs 206cc bogging down
Still too big of a prop??
Mon May 18, 2015 9:00 pm
8mph for a 5hp motor.........sounds good to me.
Mon May 18, 2015 9:04 pm
Mon May 18, 2015 9:34 pm
MPH - doesn't really justify that its bogging down. it just runs like the motor is in a constant bind.
thinking about upgrading to the predator 212.
I am building another long tail now with a predator 212 - if it operates smooth - i'll change out the briggs.
Tue May 19, 2015 6:33 am
You are asking a lot from a 5 HP engine that is on a direct drive. You need to verify your actually getting full throttle, the engine is running efficient, and your propeller is the correct size.
Tue May 19, 2015 6:50 am
Tue May 19, 2015 8:07 am
Hey don't be talking about my dog. he only weight 97lbs
Tue May 19, 2015 9:08 am
the 6.5 predator aint gonna do any better. just go with the 13.
Mon May 25, 2015 3:20 pm
the 6.5 predator does a lot better. finished build #2 sunday. predator 212 with 6' long shaft. 7x4 prop.
I have the motor hopped up a little. - bigger carb, big air filter, 18lb valve springs, different exhaust.
it pushed my boat a lot better than the other motor.
Tue May 26, 2015 6:46 am
I just trashed my Briggs 190 Intek for a predator 212. Put the marine cam, stage one kit, .016" head gasket, #39 jet and 140 emulsion tube, and a robertsons torque tube all from NRracing. I ported and polished the heads as well. Took it out with a 7.5" prop and turned it like it was nothing. Just ordered a 8" and 9" prop to see what this thing will do. Highly recommend the predator just respect the fact that the flywheel could come apart if you take out the governor.
Sat May 30, 2015 8:25 am
How deep is your prop running. You need it right below the surface to get maximum rpms, it will actually be about half in the water half out with the cab plate parallel to the surface. If it runs too deep it will really bog down that motor. Good luck
Sun May 31, 2015 10:04 am
