It is currently Fri Mar 20, 2026 2:51 am
Reply to topic  [ 84 posts ]  Go to page 1, 2, 3  Next
 Newbies first post. Working on a custom build longtail...
Post Newbies first post. Working on a custom build longtail...
Finally signed up after lurking and absorbing info and ideas.
Currently building a home made long tail for my home made duck boat.
Just wanted to introduce myself. Look forward to sharing ideas and pics with all of the MMT Members.
Mon Feb 16, 2015 2:24 pm
Post Re: Newbies first post. Working on a custom build longtail..
WELCOME! Hope your skin is thick and u can take a joke if so there is a wealth of knowledge and bullshit on here.
Mon Feb 16, 2015 4:15 pm
Yep there is a lot of anal seapage around here. People talk out there ass a bunch. I call it comedy. I've learned quite a few things also.
Mon Feb 16, 2015 4:44 pm
Welcome, I can't wait to see what you are working on. Post pics when you can
40HP Gatortail
Mon Feb 16, 2015 5:33 pm
Mon Feb 16, 2015 7:52 pm
Lets see if this posts better...
Mon Feb 16, 2015 8:02 pm
I have built two long tails both have worked great and lasted many years, but i have recently purchased a sps longtail just because i needed a small motor to run in very shallow sandy river. I am very impressed with the performance and speeds im getting out of this thing. for the price it was worth the money and i dident have to spend 30 hours in the shop. im getting 15mph on a 12ft flat-bottom with a 6.5hp motor, and running in 6 inches of water plus the alum props can take the sand. You might want to check into them and save you some time.
Tue Feb 17, 2015 5:43 pm
Tue Feb 17, 2015 8:00 pm
Cutting, Drilling, Welding... Dropped my drive shaft off at my buddies for some machine work. Im taking lots of pics. I will post a thread of the project when its done. Unfortunately the water is still hard around here. I should be done and waiting for the thaw so I can test it out.
Mon Mar 02, 2015 9:17 pm
Here are a couple sneak peek pics... Still got a lot to do.
Curently working on the transom mount and tiller handle. Then It all has to get fitted, test, then prepped for paint.
Tue Mar 10, 2015 4:34 pm
That frame looks beefy!! Good work.
-Custom pool noodle
-stage 4 water wings
Tue Mar 10, 2015 5:36 pm
Quote:
We had a lot of hunters from down under. All a bunch of great guys that liked to drink, root, and shoot shit in the dark. My kind of people.
Tue Mar 10, 2015 5:37 pm
Tue Mar 10, 2015 5:43 pm
Tue Mar 10, 2015 6:13 pm
Wed Mar 11, 2015 4:31 am
Looks good! Keep it up!
1436 Lowe
Wed Mar 11, 2015 9:47 am
Just waiting on a couple things... I need to install my throttle, my tether kill switch, my tach, and paint the frame. other than that... I really need the ice to melt so I can take it for some testing.
I ran into a couple speed bumps. I had to make new linkage and mounting brackets on the motor for the throttle. I also Took the motor apart because I wanted to remove the centrifugal governor and switch it to a set screw style throttle stop so I could better adjust it.
This motor was used in a presure washer. The governor was factory set at 3200... So I thought. I opened it up and the governor was already removed. So I tore into it for no reason other than to get a good look at everything. I am not sure why the previous owner removed the internal governor parts but left all of the external linkage in tact.
In the process of taring the motor down I decided it was a great time to paint the shroud and gas tank (no more honda red).
Tue Mar 17, 2015 4:59 pm
Looking good and welcome aboard.
Tue Mar 17, 2015 5:09 pm
I can save people agony from buying a SPS kit. Just take $300 and walk up to a pretty lady that is wearing really tall high heals. Lay on the ground, flatten your scrotum like a pancake and have her grind her heel into your sac. Pay her the money and walk away with your head held high because you just saved yourself from a lot of stress and misery of owning a SPS kit. Your welcome
23 swomp/ 1542 tracker
Tue Mar 17, 2015 6:17 pm
Tue Mar 17, 2015 6:25 pm
Earlier in the thread booner was trying to convince you to buy one
Tue Mar 17, 2015 6:29 pm
Tue Mar 17, 2015 6:56 pm
Horrible. An aluminum prop=ass ache. They would last minutes. Shaft would bend also. Wooden bushings. All in all garbage
Tue Mar 17, 2015 7:14 pm
Tue Mar 17, 2015 9:18 pm
17'Extreme Metal Fab. Skiff - 23 GDLT
Thu Mar 19, 2015 10:59 am
finished up the tiller handle. I mounted the tether kill switch, as well as the twist throttle. and after reading others suggestions, I made the twist throttle slide further up the handle, and have a nut threaded on the end. My intention is to weld some sort of handle to that nut so I can set the twist throttle and control with the end of the handle for more leverage.
Fri Mar 20, 2015 12:07 pm
Where did you get the kill switch thing'y?
Fri Mar 20, 2015 1:58 pm
I wondered how a twist throttle would work. I put a clutch lever on mine. Let us know how it works out
Fri Mar 20, 2015 2:30 pm
Fri Mar 20, 2015 8:39 pm
Fri Mar 20, 2015 8:41 pm
Fri Mar 20, 2015 8:45 pm
Sat Mar 21, 2015 6:19 pm
How did you get it to balance? Did you put the entire motor in front of the center point ( the transom mount)? Or what did you do. I'm working on one now...
Sun Mar 22, 2015 12:48 pm
Came out good!
Sun Mar 22, 2015 2:08 pm
Sun Mar 22, 2015 3:21 pm
https://youtu.be/7Mwp9W-cSEc
a short vid of it running...
One more question since I'm making the transom mount myself. How far up and down can you move the motor? As in can you get the shaft past horizontal going up and how far going down.if you could be awesome, could you post a picture at each extreme maby with a measurement of heights if that's not too much to ask. I'm trying to make myne as low profile as possible, but with the maximum amount of mobility.
Sun Mar 22, 2015 5:04 pm
Sun Mar 22, 2015 6:07 pm
That picture just made everything much smoother. Haha thank you for posting that
Sun Mar 22, 2015 7:27 pm
I was making it more complex than needed haha
