It is currently Fri Mar 20, 2026 2:51 am
Reply to topic  [ 4 posts ]
 Carb issue from a 21
Post Carb issue from a 21
Briggs discontinued the carb for the 21. Anyone else had to go this route? What's the best option? I can not be down for more than four days right now so it has to happen quick whatever I do. Thanks in advance
dipping your pen in company ink ain't as bad as swinging with branches of the family tree.
Sun Jul 05, 2015 6:05 am
Post Re: Carb issue from a 21
I bet one of the mikuni round slides would work fine (VM series). They aren't incredibly expensive. You'll have to figure what the engine needs (how many cfm the carb needs to flow) to figure out which size carb to put on it. I'd wager a bet the 22mm or something around that size would work. Do a little digging to figure out which one you need, though.
Sun Jul 05, 2015 9:06 am
Would 23hp parts work?
-Custom pool noodle
-stage 4 water wings
Sun Jul 05, 2015 12:40 pm
Quite possibly. The parts sites should have the new part numbers.
Sun Jul 05, 2015 1:22 pm
