What kind of $$$ do you think I could get for a slightly souped up honda 13?
It's recently had the governor removed. Installed a bigger carb jet, stronger valve springs; gas tank removed and pulse pump added with fitting for external fuel tank. I swapped an almost new oem replacement muffler for a header pipe and screw on mini muffler. Custom air filter and oil breather filter. Runs Great! How much $$$ should I be looking at?
Sun Aug 16, 2015 6:09 pm
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Re: $ value of modded honda 13 hp (engine only)
Maybe try a go kart forum? might be a bigger market for modded small engines.
