| Long Tail Motor Swap http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=63658 |
| Author: | Tucker1445 [ Sun Sep 13, 2015 8:04 am ] |
| Post subject: | Long Tail Motor Swap |
Newbie here, and MMT seems to have wealth of info floating around so hopefully someone can answer my question. Can I take a Beavertail frame that had a 31HP vanguard (engine blew) and do a 1 for 1 swap with a Honda GX630 without any major modifications to the frame? The shaft diameters are different so the yoke will have to change and the PTO heights have a .012" difference. Thanks for any help in advance. |
| Author: | Tucker1445 [ Thu Sep 17, 2015 9:32 am ] |
| Post subject: | Re: Long Tail Moto Swap |
Ok so I got the new to me frame home. I didn't realize I was getting the blown engine too but maybe I can sell it as a parts motor. I ordered my new GX630 today and need this monster off the frame. I'm have a hard time getting the u joint off. I'm slowly tapping it off the shaft but it'll take a while. Any thoughts or tips? I'm sure there is a very simple way I just have no idea. Sent from my iPhone using Tapatalk |
| Author: | Bigbend [ Thu Sep 17, 2015 12:37 pm ] |
What's the story on that briggs? |
| Author: | Russ [ Thu Sep 17, 2015 1:15 pm ] |
Patience and time. It'll come off. Pm sent |
| Author: | cb5331 [ Thu Sep 17, 2015 1:26 pm ] |
| Author: | jakehawk9 [ Thu Sep 17, 2015 1:27 pm ] |
Hahahaha. It's simple. get a mud motor. shoot ducks in the face. |
| Author: | Tucker1445 [ Thu Sep 17, 2015 3:30 pm ] |
Guy I got it from said he hit a log and popped the motor out of the water. A short while later Sparks and oil flew everywhere and this was the result. It looks as though the governor spring was disconnected. Maybe it just spun apart? |
| Author: | cb5331 [ Thu Sep 17, 2015 3:33 pm ] |
Only time I've seen that happen, the connecting rod came out the side. Usually a lack of oil thing... |
| Author: | Tucker1445 [ Fri Sep 18, 2015 1:49 am ] |
| Author: | tfd1224 [ Fri Sep 18, 2015 9:49 am ] |
| Author: | Tucker1445 [ Fri Sep 18, 2015 12:54 pm ] |
Yes all the set screws are removed and I filed down the spot welds on the keys. A guy I work with is gonna help me out. We'll use his tractor bucket to slightly lift it and then we are gonna hear the u joint and slowly tap it off. |
| Author: | Tucker1445 [ Mon Sep 21, 2015 4:05 pm ] |
Ok wd40 did the trick just fine. I got the new u joint, prop and motor today and what do you think... Yep bolt patter is off and I need about 1" spacers under the motor to match the previous PTO height. Sent from my iPhone using Tapatalk |
| Author: | Tucker1445 [ Mon Sep 21, 2015 4:07 pm ] |
Also where do you guys have your alternator's rectifier mounted? It says not on the engine for vibration reasons but the only place I can come up with is the u joint cage so not sure if that's any better. Sent from my iPhone using Tapatalk |
| Author: | Tucker1445 [ Tue Oct 06, 2015 6:04 pm ] |
| Post subject: | Re: Long Tail Motor Swap |
Got it all done. That Honda runs like a dream. It pushed me and two other grown men up river at 12 mph (my boat is a barge and really plows) down stream I was getting 15+ Sent from my iPhone using Tapatalk |
| Author: | Bigbend [ Tue Oct 06, 2015 7:20 pm ] |
Hell yeah man! Like the cowling too What RPMs are you at WOT? |
| Author: | Tucker1445 [ Tue Oct 06, 2015 7:31 pm ] |
Thanks my neighbor does vinyl for cars had it laying around. I'm at 3600 ish WOT with a 9x5 hill prop Sent from my iPhone using Tapatalk |
| Author: | spcamno [ Wed Oct 28, 2015 7:07 am ] |
Very nice build / swap. Do you mind to find out who makes the vinyl wrap and name of the pattern? Thank you in advance! |
| Author: | Bigbend [ Thu Oct 29, 2015 4:36 am ] |
Never seen a vinyl wrap, but pretty sure that's Max-4. I've seen guys send their cowling off to get dipped (water imaging) and turn out pretty good. It's kinda pricey though. |
| Author: | Tucker1445 [ Thu Nov 12, 2015 8:13 am ] |
Thanks. It is Max-4. Next time I see him I'll ask about the vinyl. It was just scrap he had lying around. |
