It is currently Fri Mar 27, 2026 3:14 am
Reply to topic  [ 3 posts ]
 2013 beavertail transom swivel play
Post 2013 beavertail transom swivel play
Last weekend I had vibration at the transom mount swivel. I tightened up the pivot bolt but still have about 3/16" of play where the pivot bolt goes through the transom mount. Is this normal?
Thanks
Sat Oct 31, 2015 1:58 pm
Post Re: 2013 beavertail transom swivel play
I had that issue on mine. If you try to tighten it up too much you can barely turn the motor, but it seems if you're not tight like that, there will be excess play no matter how you do it. I would buy a new locknut/nylock nut and try getting to the desired tightness.
Wed Nov 18, 2015 1:42 pm
I was thinking about drilling and tapping the nut and using a set screw to prevent the nut from loosening.
Wed Nov 18, 2015 8:56 pm
