It is currently Fri Mar 27, 2026 9:26 am
Reply to topic  [ 5 posts ]
 23hp vanguard first timer needing help!
Post 23hp vanguard first timer needing help!
As I adjusted the rpms to get 4000 wot I am now idling at 3000, can someone please lead me in the right direction
Sat Nov 14, 2015 10:01 am
Post Re: 23hp vanguard first timer needing help!
How did you make your adjustments?
1744 Phowler Prowler, 23 Dixie
Sat Nov 14, 2015 10:18 am
Does you throttle cable not have enough travel?
Sat Nov 14, 2015 10:36 am
In the tab and small spring on the left side of throttle assembly
Mon Nov 16, 2015 7:19 am
Check your throttle cable and make sure it allows full travel from wide open to idle. You can also check the tab on your idle spring.
Mon Nov 16, 2015 7:28 am
