It is currently Fri Mar 27, 2026 3:16 am
[ 5 posts ] |
20hp go devil crawfish. prop n nut lock against housing ???
mudpopper
Joined: Thu Oct 29, 2015 9:22 pm Posts: 4 Location: jupiter
i have a brand new prop, shaft, bushings, seals, yokes and ujoint on my 20hp go-devil crawsfish longtail. when i hit mid throttle the first jam nut and prop spin up the shaft and lock against the longtail housing. i have both manuals and still cant figure it out. any help would be appreciated. thanks
_________________ run it hard af or put it up. 1436 flat bottom 20hp vanguard go-devil crawfish 9x6
| Sun Nov 22, 2015 1:41 pm |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
 Re: 20hp go devil crawfish. prop n nut lock against housing
Yu should have 2 jamb nuts upstream of your prop, set your gap between your end housing and tighten the two nuts against each other as hard as you can. I had a friend and myself to do it and we were on them with 24" Cresent wrenches. When you spin your prop against your nuts and it hits the nuts. Get a mallet or a plastic dead blow hammer and put a screwdriver in the u joint yoke. Hammer on the prop until you've realize it won't go anymore. I then use a jam nut and a lock nut on the "terminating" side of the prop. Repeat the tightening process. USE ANTI-SIEZE BEFORE ANYTHING GOES ON YOUR PROP SHAFT THREADS... some people say to use the low profile jam nuts. I used full sized 3/4 nuts as my jam nuts. I found it easier to tighten them down hard. I believe the box end wrench size for a 3/4 nut is 1 1/8 if I remember right
| Mon Nov 23, 2015 6:06 am |
mudpopper
thank you brother, i was thinking it needs 2 jam nuts upstream but the paper work says 1. thats what i get for tryin to follow directions.goin to test it out now. thanks again
| Mon Nov 23, 2015 10:33 am |
jakehawk9
No problem. Those top two need to be stupid tight against each other
| Mon Nov 23, 2015 11:45 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
_________________ so many rivers, so little time
| Tue Nov 24, 2015 3:18 am |
[ 5 posts ] |
