It is currently Fri Mar 27, 2026 9:28 am
Reply to topic  [ 4 posts ]
 High transom or low transom model how do you tell the diff
Post High transom or low transom model how do you tell the diff
Can someone explain how do you tell whether your longtail is a high transom model or a low transom model? What is the key to this, I am thinking it is something in the motor bracket but I could be way off. thanks.
Fri Jan 15, 2016 10:51 am
Post Re: High transom or low transom model how do you tell the d
Measure from the bottom of the u joint to the end of the shaft. Most short transom longtails are less than 72"... using that method, if it's a little less than 72" that's because there's about 1 or 2 inches of shaft in the u joint. If it's considerably less like in the neighborhood of 60" it's a short transom.
Fri Jan 15, 2016 12:40 pm
I thought most longtails were made for short transom? :?
Fri Jan 15, 2016 8:03 pm
Not entirely true. alot of places have an option on shaft length if you are ordering directly from them. For example backwater has a 59" and a 71". You need a longer one for a tall transom due to shaft and prop angle relative to the water line. I'm pretty sure backwater had the different shaft lengths listed as tall and short transom
Fri Jan 15, 2016 8:57 pm
