High transom or low transom model how do you tell the diff
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=65396
Author:  colnz [ Fri Jan 15, 2016 10:51 am ]
Post subject:  High transom or low transom model how do you tell the diff
Can someone explain how do you tell whether your longtail is a high transom model or a low transom model? What is the key to this, I am thinking it is something in the motor bracket but I could be way off. thanks.
Author:  jakehawk9 [ Fri Jan 15, 2016 12:40 pm ]
Post subject:  Re: High transom or low transom model how do you tell the d
Measure from the bottom of the u joint to the end of the shaft. Most short transom longtails are less than 72"... using that method, if it's a little less than 72" that's because there's about 1 or 2 inches of shaft in the u joint. If it's considerably less like in the neighborhood of 60" it's a short transom.
Author:  brycecheramie [ Fri Jan 15, 2016 8:03 pm ]
I thought most longtails were made for short transom? :?
Author:  jakehawk9 [ Fri Jan 15, 2016 8:57 pm ]
Not entirely true. alot of places have an option on shaft length if you are ordering directly from them. For example backwater has a 59" and a 71". You need a longer one for a tall transom due to shaft and prop angle relative to the water line. I'm pretty sure backwater had the different shaft lengths listed as tall and short transom
