I am purchasing a swomp 59" shaft from back water.. but don't know how long tails perform best on what hulls... I am looking at a 16-17' hull 38-40" wide... What would best suit this motor... I will be using this set up in cypress swamps without actual runs... just picking my way threw slowly with hard bottom an shallow waters most of the time so bouncy is a factor but would 2" on a rounded bottom make that much of a difference? I run alone 7 gals of gas n battery in front open hull light as possible... So 16x40? 16x38? 17x40? 17x38? I run alot of shallow hard bottoms skinny runs open water time to time..
_________________ Going to Disney World is like Going To the DMV, Instead of Walking out Once Finished Jumping Back In Line At the DMV…
Fri Feb 12, 2016 9:36 am
brycecheramie
Re: new to longtails..hull question
edit. Post the damn question one time so you don't get multiple answers...
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
