Help with a longtail set-up
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=6672
Author:  Tcounty [ Mon Dec 21, 2009 11:02 am ]
Post subject:  Help with a longtail set-up
How low in the water should my prop be running? At wot it is about 1' under the surface, is that right, or do I need to adjust my calvitation plate to make it ride higher? It's on a 1438 jon boat, 13 hp scavenger. I MIGHT be getting 8 mph. It does squat some in the back but I think it's due to the prop being so low in the water. With the handle that is on it I'm sitting in the middle of the boat,
Author:  lparrish [ Tue Dec 22, 2009 8:55 pm ]
Post subject:  Re: Help with a longtail set-up
My cavitation plate runs about 1" under the water. If I adjust it any high it wants to blow out of the water. From what I have read and seen 1" is about right.
Author:  gonehunten [ Tue Dec 22, 2009 9:05 pm ]
that were im running my godevil LT.and if you go to low it hits everything ,it seems.
Author:  Tcounty [ Wed Dec 23, 2009 8:15 am ]
I can force it ,by pushing down ,to run 1" below the surface, but I loose speed. I think its due to the calvitation plate being angled down. The one on the scavenger is adjustable. It is mounted on studs. All I need to do is put washers on the front studs, and it should point the plate up some, that should raise the prop.
