It is currently Tue Sep 23, 2025 8:19 am
Reply to topic  [ 5 posts ]
 Mud buddy long tail seal/shaft question
Post Mud buddy long tail seal/shaft question
Hi, I have a lower seal that is leaking ( grease coming out between the seal cap and prop nut). I’m assuming I need a new lower seal set, but I also notice that the shaft itself has a little play in it where it will move in and out about 1/16 of an inch when the drive is turning while engine is running. It doesn’t have any side to side movement that I can see when prop is spinning. Would that indicate a bent shaft still? And if I put a new seal set in would I just be wasting my time without replacing the shaft?
Any input appreciated. Thanks, Matt
Thu Aug 06, 2020 8:04 am
Post Re: Mud buddy long tail seal/shaft question
When you do the seal, definitely do the bearings, but whether or not you do the shaft or u joints is up to you.
#mudmotor>physics
Thu Aug 06, 2020 8:13 am
I appreciate it. Do you have any tips to get the lower bearing out of the bearing housing, do I need to take the whole housing off then use a two jaw puller to get the bearing out? Or can I get the bearing off the shaft with leaving the housing on. Thanks
Thu Aug 06, 2020 10:56 am
Umm, been 8 years since I've pulled one apart. Pretty sure we just pulled the whole shaft. Not gonna be much help there. Sorry.
#mudmotor>physics
Thu Aug 06, 2020 11:19 am
No problem thanks for the reply
Thu Aug 06, 2020 2:00 pm
