BW cavitation plate rubber seal
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=67365
Author:  Glades Ranger [ Fri Jul 01, 2016 5:45 am ]
Post subject:  BW cavitation plate rubber seal
Seems like 4100 rpm and 20.6 mph with the 9x6 prop is my final number, with my BackH20 26.5 EFI, for which I am most pleased. After having removed and replaced the cavitation plate several times in the process of dialing in the motor and trying out a different prop, the rubber gap seal at the top of the plate, which "seals" the gap between the plate and shaft housing is stretched, mostly from my mis-positioning it. Anybody replace this yet? Seems like I could use a piece of rubber hose and cut a slit in it and slide it over the plate edge. Any suggestions for size/brand/material for this?
I will probably do a few more runs, with both the 9x6 and 9x7, this time simulating a hunting load, and then decide which prop to use.
By the way, while the boat was in the water, I installed some EZ slide pads on the trailer bunks. Amazing how much more easily the boat loads/unloads from the trailer now! Why didn't I do this years ago?? :ugeek:
Author:  huck Finn [ Fri Jul 01, 2016 6:41 am ]
Post subject:  Re: BW cavitation plate rubber seal
5/16 fuel line scrap , slit with a razor knife , I change them all the time.
H Finn
Author:  stu [ Fri Jul 01, 2016 7:08 am ]
Gotta make a note of that. Glades, refresh my memory. Did you pick up any speed with the 9/6 prop?
Author:  Glades Ranger [ Fri Jul 01, 2016 9:54 am ]
Stu, good to hear from you! Water has crept up, got in about a 1/3 of a mile and then I was not so adventurous. :mrgreen: I picked up nominally .5 mph. I tweaked the throttle up to 4300 rpm but I have hit a plateau at 4100 rpms @ 20.5 mph. This is with the 9x6. I will test again with the 9x7 and more weight up front and then determine what may be best.
Thank you Huck Finn! I will replace with that and once I finalize the prop to use, will Loctite the cavitation plate bolts!
I still need to move the motor up to the back hole to tip motor weight slightly forward to ease the lifting of prop.
Author:  stu [ Fri Jul 01, 2016 12:09 pm ]
Good speeds Glades. It probably won't drop off much with a hunt load. Lost one Cav plate last year because I didn't check the bolts. Now I use lock tight on all four and nylocks on back two bolts. Have a great weekend and Happy 4th.
Author:  Glades Ranger [ Fri Jul 01, 2016 3:09 pm ]
Thanks, Stu, same to you and yours!
Author:  Glades Ranger [ Wed Jul 06, 2016 9:49 am ]
Found a near identical hose(seal) at auto parts, Autocraft vacuum hose 7_64 " (2.8 mm) SAE J1037 part# AC3339P (Advance auto parts), flexible but stronger fits perfect between cavitation plate and shaft housing! :geek: $3.64 for 6', should last a while 5 :mrgreen:
