| Different grease? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=67667 |
| Author: | libertarian [ Wed Jul 27, 2016 5:54 pm ] |
| Post subject: | Different grease? |
What grease has anyone used on a GD 23HP longtail besides the red GD grease? I'm thinking any marine type high quality grease should be OK. Anything to definitely NOT use? |
| Author: | flint87 [ Wed Jul 27, 2016 6:37 pm ] |
| Post subject: | Re: Different grease? |
Lucas red n tacky Sent from my iPhone using Tapatalk |
| Author: | SETx Longtail [ Wed Jul 27, 2016 7:23 pm ] |
Lucas red n tacky here too. Use it on every boat motor, trailer, vehicle and piece of equipment I own. Doesn't hurt I get it by the case at work. |
| Author: | huck Finn [ Wed Jul 27, 2016 8:01 pm ] |
| Author: | tyler_johnson [ Wed Jul 27, 2016 10:34 pm ] |
I run the amsoil, starting third year on my trailer and still have no slack in wheel bearings, pump a little before every move and it goes in everything I have that has a grease fitting. just my experience is a little tlc with any grease goes along ways Sent from my SM-G900V using Tapatalk |
| Author: | MatterOM [ Thu Jul 28, 2016 4:16 am ] |
| Author: | NinjaButtpirate [ Tue Aug 02, 2016 7:29 am ] |
Green marine grease from autozone Sent from my iPhone using Tapatalk |
| Author: | Shore Bird [ Wed Aug 24, 2016 8:11 pm ] |
I use AMS oil and have not had a problem. Very good chemistry in their products. I also use it in all my trailer bearings and hit the grease points with it on my Honda 15hp outboard. Sent from my iPad using Tapatalk |
| Author: | bushwacker34 [ Thu Aug 25, 2016 9:57 pm ] |
I use smitty's red #2 high temp lith grease. No trouble so far! Sent from my iPhone using Tapatalk |
| Author: | Glades Ranger [ Sat Aug 27, 2016 6:16 am ] |
Brylcreem, if you can find it. |
| Author: | teammarshmafia [ Sat Aug 27, 2016 6:26 am ] |
X3 on da Lucas red n tacky. The Stuff is great! I also use it on everything from tractors to boats Sent from my SAMSUNG-SM-G890A using Tapatalk |
| Author: | flint87 [ Sat Aug 27, 2016 12:18 pm ] |
| Author: | jc [ Sat Aug 27, 2016 2:14 pm ] |
I must have got a bad tube of the Lucas red n tacky because I used it on a trailer when I put new wheel bearings in and that stuff got runny like honey and leaked out of some brand new bearing buddys. |
| Author: | SETx Longtail [ Sat Aug 27, 2016 2:19 pm ] |
Sounds like it. I've been using it for years on all sorts of equipment and never had an issue with it thinning. I replaced my trailer hubs and bearings a couple months ago and haven't seen anything come out of the bearing buddies except for what leaked out the relief hole like it's supposed to. |
| Author: | flint87 [ Sat Aug 27, 2016 2:30 pm ] |
The blue Lucas extra heavy duty is good shit too. We use it on our bobcats and mini excavators at work and they get run hard Sent from my iPhone using Tapatalk |
| Author: | Glades Ranger [ Sun Aug 28, 2016 6:20 am ] |
Just remembered a good one- Aqualube, I think the company is in Ky. If you have some extra dough, Mobil 1 synthetic is very good also; after break-in, or after your first oil change, IMO both synthetic oil and grease are recommendable. |
| Author: | libertarian [ Sun Aug 28, 2016 4:47 pm ] |
I run Mobil1 grease in the 5th wheel. Synthetic Rotella 5W-40 oil in the GD and all the other small engines. I'm experimenting with WalMart marine grease in the GD trailer bearings. So far it works good. I can't find that old Pennzoil blue marine grease anywhere. Lucas Red & Tacky will go in the GD. |
| Author: | Burch [ Wed Aug 31, 2016 9:45 pm ] |
If I remember correctly, any waterproof #2 grease is fine. But, I always used Aqualube. You won't save any money if you have a bearing failure because of cheap grease. |
