| Newbie question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=67760 |
| Author: | Powderedtoastman [ Wed Aug 03, 2016 10:58 pm ] |
| Post subject: | Newbie question |
Hey all! I'm a long time viewer here but finally decided to register. I'm building an 8 HP Longtail and have my shaft, housing, and bearings/bushings/seals all together. My question is, what keeps the shaft in place once it is all built? It seems like the universal joint is the only thing keeping the shaft from slipping out of the housing. Thanks a bunch! |
| Author: | 45th parallel [ Thu Aug 04, 2016 11:25 am ] |
| Post subject: | Re: Newbie question |
The U joint, that's why longtails don't have reverse! Seriously, make certain you have a flat spot ground into your shaft for the u-joint bolts to grab and not mar the OD of the shaft( de-burred super smooth so you don't damage the seals when assembling or changing shafts). Safety wire the u-joint bolts. You can get a wire twister and some stainless wire cheap at Harbor Freight. http://www.harborfreight.com/9-inch-saf ... 45341.html You'll also want to peen the key so it stays put. You can tack weld it if you don't get carried away and don't mind grinding it later and again deburring. |
