| New rig http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=68030 |
| Author: | phoneman7 [ Sat Aug 27, 2016 6:54 pm ] |
| Post subject: | New rig |
Been wanting another longtail rig for awhile but hated to spend the money on a new one. Found a 1638gd with 23 gdlt on it today. Frame needs new bushings and shaft and all but im pretty stoked. Ive had godevils mudbuddy and prodrive and going back old school. Really wanted to try a backwater but got this rig for way less than i could have bought just the motor |
| Author: | SETx Longtail [ Sat Aug 27, 2016 7:10 pm ] |
| Post subject: | Re: New rig |
Congrats! I wouldn't mind having that exact size and combo as a second boat in the fleet. |
| Author: | huck Finn [ Sat Aug 27, 2016 7:50 pm ] |
I've almost that exact hull , it's a good platform , go anywhere rig . Congrats . You'll probably see. 19-21 mph normal cruising . H Finn |
| Author: | phoneman7 [ Sat Aug 27, 2016 8:42 pm ] |
I stay in tight timber and small hard bottom rivers. Its gonna be perfect. She is a tiny little thing. |
| Author: | Glades Ranger [ Sun Aug 28, 2016 6:37 am ] |
Good deal! Can't beat that recoil start if your battery runs down...you might want to go ahead and invest in a carburetor kit and rebuild that one to avoid problems. Run seafoam/stabil in the gas. A longtail will keep your arms limber; make sure the kill switch works and wear your lanyard in the timber... |
| Author: | phoneman7 [ Sun Aug 28, 2016 8:42 am ] |
Yeah ive gotta go through it and put new seals and bushings in it. Deff gotta freshen up motor with new plugs and such. Itll be ready for some teal birds soon |
| Author: | phoneman7 [ Mon Aug 29, 2016 6:55 pm ] |
Stripped old floor out today and about 150lbs of foam. Gotta cut out new floor and get some paint on |
| Author: | Glades Ranger [ Tue Aug 30, 2016 6:24 am ] |
I know lots hate the flotation but there is some closed cell flotation/foam that works; I'd rather have some than none. Makes for a quiet, insulated floor. You can go with ss screws/washers so floor is not a real drudgery to remove. The stuff I ripped out of one rear pod on my grizzly was dry after a number of years. Instead of paint I recommend hydro-turf. Look for closeout sheets and specials to save $. |
| Author: | phoneman7 [ Tue Aug 30, 2016 3:51 pm ] |
Oh ill put hydroturf on floor. All my boats have it. I was talking about painting rest of boat. |
| Author: | phoneman7 [ Mon Sep 05, 2016 12:07 pm ] |
Longtail needs lots of work. Skeg is cracked and shaft, bearings and prop gotta be replaced. |
| Author: | Glades Ranger [ Wed Sep 07, 2016 6:38 am ] |
phoneman7, did you get in touch with GD? As you probably now you need to give them the serial number stamped on the frame and they will give you what you need. Hope you can get it ready for teal season! |
