It is currently Mon Mar 23, 2026 3:54 am
Reply to topic  [ 12 posts ]
 dual motors single prop
Post dual motors single prop
I'v been contemplating on building a mud motor for my small boat a long tail is my choice on the type. As far as hp more is better right? but is two better then 1?
I'm looking at 2 HF 6.5 hp engine join together by a chain on a go cart type clutch on each motor and one sprocket in the center with a pillow block attaching the shaft.
Pros.
More hp for less money
useable clutches
changeable gearing for more speed out of the motors
cons
Slightly more weight
more parts to brake
I would like to achieve the speed of a short tail but the abilities of a long tail.
Here is my questions to you all Have you ever seen anyone attempt this?
Attached my concept for the idea
Fri Sep 16, 2016 6:16 pm
Post Re: dual motors single prop
Interesting concept, I've personally never seen anything like it. Best of luck with this build I'll be watching to see how it comes out!
Sent using smoke signals
15/42 Alweld 25 MBLT
Sat Sep 17, 2016 5:18 pm
Seems like it would be tough to keep both motors perfectly in sync. Good luck
Sent from my SAMSUNG-SM-G891A using Tapatalk
Tue Sep 20, 2016 7:08 am
I don't want to sound negative or rain on your parade...but I think the only reason to do this would be for the satisfaction of doing it and having something unique. I don't believe it would ever be as reliable as simply using a 14-18hp single engine and drive.
The more moving parts, the more problems. If you take it on though, it would definitely be a conversation piece!
Tue Sep 20, 2016 7:27 am
Be a neat project,I have been dreaming up a 90 horsepower Honda D15 engine set up.
Tue Sep 20, 2016 8:33 am
Theres a longtail with one motor in front of the other, seen it a few years ago
Tue Sep 20, 2016 10:30 am
just a thought but if you have ever seen a tractor pull contest they stack multipul engines on a tractor I donno how they get all too work on one axel but it might help you
Tue Sep 20, 2016 2:14 pm
You have a good idea for a clutch on each motor, that will eliminate any rpm differences. I would suggest belts over chain though.
Wed Sep 21, 2016 6:05 am
Almost all Navy ships use two engines per shaft coupled through a reduction gear and in design aren't that much different than a long tail, just with inboard engines. With clutches, I see no reason why it wouldn't work and it should weigh less than using two longtail engine setups. Weight of a 20hp LT vs. a twin engined single shaft LT? Shouldn't be too much off. What I've noticed here lately is that there are a whole lot more performance parts for smaller engines than there are for larger HP engines.
Joel
norcal
Sat Oct 08, 2016 12:16 pm
Mudbuddy built the Dominator years ago..
download/file.php?id=34955&mode=view
Sat Oct 22, 2016 9:03 am
Dam that's a good one
Sat Oct 22, 2016 5:20 pm
yea, mb had one several years ago. i'm sure they copied it from somebody else. lol
there are vids of it on youtube.
Sat Oct 22, 2016 5:22 pm
cron
