It is currently Wed Mar 25, 2026 3:29 am
[ 5 posts ] |
Mpe_tx3
 Towing long tail
New long tail owner here. Do you guys mount your motors with the tail in the boat while towing or leave it extended? I always thought you reversed it and put the tail in the boat but the guy I bought it from drove with his facing out
| Mon Oct 24, 2016 12:07 pm |
flint87
 Re: Towing long tail
| Mon Oct 24, 2016 4:35 pm |
Marshall
If you can swing yoir shaft around into the boat, that is the preferred method. Transporting any boat, over land on a trailer, causes the motor to put stresses on a transom that it was not designed for. Be it a longtail, surface drive, or outboard, are made to sit on a transom and push. Like a bulldozer. When towing, the motor jumps around in all directions. None of which are the ones it is designed to move in. If the tail has to hang out, make a transom saver, and try to stabilize It as best you can. On my rig I remove the shaft, remove the motor from the mount, and place them on the deck of my boat. I have a Mudskipper setup with the 420cc predator engine with loop header and cavitation plate.
| Sun Dec 04, 2016 6:18 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
If it doesn't swing into boat, then get a good ratchet strap, center motor with handle is boat. Wrap once around handle and then wrap around boat and trailer and then ratchet down tightly. the motor will "bounce" some. I towed a 16 hp GDLT like that for better than 10 years! With no Problems except sometimes I would lose my flag so I got a roll orange marker tape!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Mon Dec 05, 2016 9:02 am |
NinjaButtpirate
| Sat Dec 24, 2016 3:50 am |
[ 5 posts ] |
