Automatic lubricator
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=68961
Author:  Mpe_tx3 [ Wed Nov 16, 2016 2:45 pm ]
Post subject:  Automatic lubricator
Wanted to see if anyone could give some insight into the automatic lubricator on a go devil. I can't figure if I'm supposed to just fill the lubricator compartment up or if I have to have a certain grease gun tip to get it actually inside the tail. I tried calling go devil and all the lady said was to not grease the lubricator seal (which I knew) then offered to send me a manual. Do you simply fill the entire thing with lubricant or do you need a needle styled grease tip to force it into the long tail? Thanks a ton
Author:  bbb [ Wed Nov 16, 2016 3:08 pm ]
The shaft should have a grease fitting about halfway down the shaft below the lubricator.
You pump the grease into here and any overflow pushes into the lubricator. As soon grease starts to overflow into the lubricator, stop. You're done.
Should only take 3-4 pumps usually. If it consistently takes 6-7, you probably need to replace seals and bushing.
Author:  Mpe_tx3 [ Wed Nov 16, 2016 3:16 pm ]
Post subject:  Re: Automatic lubricator
Is the fitting separate from the reservoir that is near the engine? When I bought it I was told to put the lubricant in the reservoir with the spring
Author:  Bigbend [ Wed Nov 16, 2016 3:48 pm ]
Don't put it directly into the lubricator. There is a separate fitting. The go devil manual is on there website and illustrates it.
Author:  cb5331 [ Wed Nov 16, 2016 4:08 pm ]
He doesn't want to look at the manual they offered to send him. He'd rather have someone explain to him what's in the manual, which has been done multiple times now. Just let him fill the lubricator like he wants to.
Author:  bbb [ Wed Nov 16, 2016 4:38 pm ]
Author:  SETx Longtail [ Wed Nov 16, 2016 6:29 pm ]
No no no.... Just fill that lubricator itself, don't worry about that silly grease fitting. I'm sure it's just there for looks anyway.
Author:  dead animal [ Wed Nov 16, 2016 8:39 pm ]
THEY SHOULD PUT A ZERK OR SOMETHING NEXT TO THE LBRICATOR THINGY TO FILL UP THE LUBRICATOR!!!
Author:  CypressCritter [ Fri Nov 18, 2016 9:00 am ]
Damn :shock: Zerk on the shaft should fill the lubricator, if not then pump the zerk full and then push down on top of lubricator and twist slightly to remove the top. 8-)
