It is currently Tue Mar 31, 2026 5:42 am
Reply to topic  [ 12 posts ]
 help with hull choice
Post help with hull choice
Hey guys im wondering what size hull you think would work ok for a 13hp longtail im thinking 1636 or even 1836 in .80 or should i look into something smaller i know it will get destroyed but i only need it to last a few seasons thanks
Mon May 22, 2017 11:20 am
Post Re: help with hull choice
16x40
IMO
Mon May 22, 2017 11:27 am
Second that, maybe even an 1844 in case you upgrade the motor... I had a 1436 with an 18 HP LT and survived, that was a .072. Unless you are purposely set on destroying a hull, even a lightweight rivetted hull will last a long time and rivets can be fixed. The reason I say longer-wider is you will still get decent performance and most of us morph into something bigger anyway, and you will ready for another hunter or retriever or a few more decoys or one of those hernia'producing yeti coolers. :mrgreen:
Tue May 23, 2017 3:03 am
Tue May 23, 2017 4:16 am
There you go, corroboration! I should bought the 1848 riveted jon short transom when it was available back in 2004. IMO most of the new factory jons are too azz heavy- that is why I dropped 45# myself! :mrgreen:
Tue May 23, 2017 6:17 am
I run a 1648 riveted flat bottom John boat with a 9hp LT. it runs 12mph and pushes me over submerged logs. I know I'm under powered but it's still a good set up for me.
Thu May 25, 2017 8:00 pm
With two people now im doing 9 with a 6.5hp longtail do you think it would be any faster with the 1640 and 13hp or about the same
Fri May 26, 2017 5:32 am
Fri May 26, 2017 5:38 am
How are we supposed to know what size hull you have it on?
Its on a 1436 now
Fri May 26, 2017 6:02 am
You will see better speeds with the bigger motor and hull
Fri May 26, 2017 6:06 am
Lowe 16x44 16hp GDLT 13-15 mph with 2 adults, dog, and gear. No mods.
Fri May 26, 2017 7:58 am
