It is currently Fri Mar 27, 2026 4:58 am
[ 6 posts ] |
Reinforce transom / Mounting GD25
Mothra
Greetings all! First post. Just got a new (to me) 25hp GD long tail and am getting ready to mount it on my 1548 SeaArk. Replacing a 30hp outboard. Do I need to reinforce the transom by welding an aluminum plate to the back of the boat? Should I replace the mounting screws that hold the motor on with bolts that mount through the transom? I don't want the motor to come un-clamped and fall off. Thanks.
| Tue Jun 20, 2017 3:09 pm |
Glades Ranger
 Re: Reinforce transom / Mounting GD25
Reinforcement should help but that transom should suffice, thru-bolt is a good safety idea and theft deterrent!
| Wed Jun 21, 2017 9:20 pm |
flint87
I have yet to run across a gdlt that had thru bolts
| Thu Jun 22, 2017 5:35 am |
Glades Ranger
Flint is right, the GoDevil manual states to tighten clamp bolts very tightly, that no thru-bolts are necessary- sorry I presently own a BW LT and my transom mount required bolts, and I did run GD's for years, and just had a senior moment...I do recommend periodically checking transom bolts because they can loosen over time/use, as the GD manual also states to check engine mount bolts. The only other advice is to definitely wear your kill switch and have fun!
| Thu Jun 22, 2017 5:52 am |
Russ
Doubtful that it'll fall off just being clamped, but the thru bolts make it more difficult for someone to just loosen a couple clamps and walk off with your motor. It doesn't take much to do, and slows down would-be theft.
| Thu Jun 22, 2017 5:55 am |
BassmasterCia
Joined: Sat May 10, 2014 5:50 pm Posts: 660 Location: Arkansas
Not to mention the thru bolts keeps the motor from loosening off and vibrating sideways. Which reminds me, i still need to move mine back over and bolt it.
_________________ 15x36 Go Devil Duck Skiff with a Go Devil Longtail.
| Sun Jun 25, 2017 7:34 pm |
[ 6 posts ] |
