| 35hp backwater http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=70648 |
| Author: | Cor_ruthless [ Tue Jun 20, 2017 7:49 am ] |
| Post subject: | 35hp backwater |
What opinions on performance? And which boat to go with. Had a 1544 with a 27hp longtail and bought a 23 hp copperhead and hate it.... the copperhead doesn't get anywhere my longtail would take me.... I'm torn between a 35 GTR or a 35 LT with a 1748 size boat What are your guys opinion? |
| Author: | Glades Ranger [ Wed Jun 21, 2017 9:27 pm ] |
| Post subject: | Re: 35hp backwater |
If you liked your 27 Lt, a 35 will be better...but if you are carrying big # and going long distances, the SD 35 is better, all depends where you run |
| Author: | Cor_ruthless [ Thu Jun 22, 2017 4:49 am ] |
Glades, seeing your from south Florida I sure we probably run the same places. Running lake okeechobe couple weeks ago I couldn't stop if not I was stuck. I'm sure you been running a long time back man longtails is were it's at. |
| Author: | Glades Ranger [ Thu Jun 22, 2017 5:59 am ] |
On Memorial day I only got 100 yards into the glades and then bottomed out- very little water. Last week, after all the rain, the FWC announced closures to the WMA's down here because of high water! I see the lake is back over 12' and that is good! Been running LT's since 1986, and I love my BW 26.5 EFI LT! The O's bottom is hard sand/marl in most places and you are better off with an LT- you will bottom out quicker with an LT than a SD- the SD will go in farther but then you will be bad azz stuck and good luck with that and your prop is probably history. I almost bought a copperhead 23 but it was more $ than my BW, and I am stubborn after 31 years, and the LT just plain works...now if I was carrying three hunters and gear and making longer runs, a big block SD would be just fine. |
| Author: | Cor_ruthless [ Thu Jun 22, 2017 6:24 am ] |
Yeah man makes sense. Guess you can't have everything appreciate the input! Maybe I'll see you around the glades! |
| Author: | FRANKtheTAU [ Thu Jun 22, 2017 9:27 am ] |
I had the 35 and really liked it. I eventually bumped up to the 37 and IMO the benefits of EFI were unbelievable. Super easy starting, extremely smooth idle and acceleration, etc. Regardless of if you go 35 or 37, the big block SWOMP motors from Backwater are incredible. Were you unhappy with the Copperhead specifically or just the surface drive platform in general? If you didn't like the capabilities of the surface drive as opposed to a long tail, you have have already answered your GTR vs Backwater question. Try to get some stick time with each motor and go from there! Best of luck on your decision. |
| Author: | Cor_ruthless [ Thu Jun 22, 2017 1:35 pm ] |
Frank Water level got real low and the copperhead will rip throw it but you can't stop. I did get out but almost an hour later. My longtail days I never had that problem. Went frogging and we couldnh even get close to them due to the fact that we had to keep a fast speed. A guy with a gatortail had a rough time and he got through. Make u think if 8k is really worth the investment on a GTR. Honestly I'm anxious for the season when the Water is higher. Next season I'm buying a 1748 crawdad from weldbilt. Gonna keep my copperhead and if it performs for what I need then fine if not the backwater will be my next purchase. |
| Author: | Walkerdogman85 [ Fri Jun 23, 2017 6:13 pm ] |
I have a 35 backwater and love it!!! I used to run an outboard jet and don't see myself going back. Plenty of power with the 35. I have it on an Alweld 1752 and it carries a load very well with the 9x8 prop running 23 solo with fishing load and a plywood floor. I've had 10 people in it and still went up river at 12-13 mph... |
| Author: | brycecheramie [ Fri Jun 23, 2017 6:15 pm ] |
10 people in a 1752 isn't probably the best idea |
| Author: | Russ [ Fri Jun 23, 2017 6:47 pm ] |
*facepalm* Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | Russ [ Fri Jun 23, 2017 7:13 pm ] |
I'm a French model. Bonjour. Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | brycecheramie [ Fri Jun 23, 2017 7:40 pm ] |
Can't believe everything you see on the internet lol |
| Author: | huck Finn [ Fri Jun 23, 2017 9:56 pm ] |
| Author: | Russ [ Sat Jun 24, 2017 9:16 am ] |
A khaki colored bedazzled speedo Sent from my SAMSUNG-SM-G891A using Tapatalk |
| Author: | cb5331 [ Sat Jun 24, 2017 11:21 am ] |
You sound hideous. |
| Author: | Walkerdogman85 [ Sat Jun 24, 2017 7:29 pm ] |
My point was it carries a load very well. |
| Author: | brycecheramie [ Sat Jun 24, 2017 7:53 pm ] |
Carries a load well, and carries can actual elephant are 2 different things! |
| Author: | Walkerdogman85 [ Sat Jun 24, 2017 8:24 pm ] |
However you want to look at it... |
