spooky
help ID frame?
I just scored this 13hp LT in a trade and was wondering if Anyone could ID the frame. The guy I got it from said that it was a home build (not by him). If it is a home build, someone did a damn good job,, evertyhing is down to the 16th. I think it has about a 65" shaft that is 3/4" dia..
Thu Jul 27, 2017 8:37 am |
spooky
Re: help ID frame?
Also, the guy told me the prop was crap. What props should I be lookin at?
Thu Jul 27, 2017 8:40 am |
Will C
Re: help ID frame?
Definately homemade. At least the shaft thread is a common 3/4. Call backwater and tell them your horsepower, they will hook u up with a prop
Thu Jul 27, 2017 9:07 am |
Will C
Re: help ID frame?
Thats backwater inc.
spooky
Re: help ID frame?
Thanks for the reply. I was thinking it was home made. Maybe from the mad MM plans? Eigther way its built legit.. The transom mount is crap so I gotta redo that but other than that Im feelin good about it. Gotta add a safety kill switch and a throttle cable and Im good to go I think...
Thu Jul 27, 2017 9:14 am |
Will C
Re: help ID frame?
The bushings and seals or lack of will prob give problems . I say get it running good, enjoy it for a bit, then sell it and upgrade
Thu Jul 27, 2017 10:57 am |
spooky
Re: help ID frame?
I think its got 3 bushings in it,, Atleast theres 3 set screws that look like they would hold bushings. If it ever comes to too much trouble I wonder if I could make Backwaters enclosed bearing sets work?? Recon Ill cross that bridge when I get there. I got about 5 or so acres of swamp on the back of my property and I aint diggin waiding through it in the dark with the gators. Iv never been able to hunt that place like I want to until now. Between there and dickin off in a few creeks around here I probably wont put 20hrs a year on the engine.
Thu Jul 27, 2017 11:24 am |
Darryle
Joined: Sun Mar 22, 2009 3:44 pm Posts: 250 Location: Fort Worth, Texas
Re: help ID frame?
It will probably be fine, keep it greased and out of the water when not in use and the bushings will last longer than you think
1244 Atchafalaya Outdoor Designs W/ 12hp Copperhead
_________________ 2017 Atchafalaya Outdoor Designs 1244 2017 Copperhead 12hp
Thu Jul 27, 2017 12:37 pm |
