throttle cable question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=70986 |
Author: | spooky [ Tue Aug 08, 2017 11:43 am ] |
Post subject: | throttle cable question |
how are yall hooking up the cable to the linkage? I got a bicycle brake lever for the throttle, but not sure how to hook the cable on the engine side. thanks |
Author: | Will C [ Tue Aug 08, 2017 3:37 pm ] |
Post subject: | Re: throttle cable question |
What kind of engine are we talkin about |
Author: | spooky [ Tue Aug 08, 2017 4:06 pm ] |
not sure. what I can say is it was blue (before I camo'd it) and it is a 13hp. got it on a trade. here is a thread I made that might help.. I think its a duromax??? viewtopic.php?f=6&t=70894 |
Author: | huck Finn [ Tue Aug 08, 2017 5:28 pm ] |
Hook one end to the inside slot on the lever, run the other end to the stock carb linkage . Get all your slack out so lever is idle at natural place. Make sure you add a spring to back of linkage, enough to snap your lever back to nuteral as you let off. H Finn |
Author: | spooky [ Tue Aug 08, 2017 5:39 pm ] |
Author: | huck Finn [ Wed Aug 09, 2017 7:16 am ] |
Gotcha, well hmmm I've seen the lead cylinder types at tractor supply. They have a pre drilled hole with a set screw on the bottom. You have to feed it thru then screw it down to hold cable secure. Probably work for you . H Finn |
Author: | Russ [ Wed Aug 09, 2017 8:53 am ] |
Either get the cable end like huck spoke of, or get out your soldering gun and make it. Bend the cable with pliers to fit the carb linkage, then use solder to stiffen the bends and end and thicken it just a bit. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | spooky [ Wed Aug 09, 2017 6:30 pm ] |
alright,, thanks yall. Ill look for those things with the set screw AND solder it in. I tend to go overboard. |
