30hp Kohler on a 27 Kohler GDLT frame????????
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=7136
Author:  JpEater [ Thu Jan 14, 2010 2:39 pm ]
Post subject:  30hp Kohler on a 27 Kohler GDLT frame????????
WIll a 30hp kohler fit on a 27 kohler GDLT frame? Everything appears to be the same. Just wondering if anyone has done this before I buy.
Author:  cb5331 [ Thu Jan 14, 2010 3:16 pm ]
Post subject:  Re: 30hp Kohler on a 27 Kohler GDLT frame????????
Try giving gd a call. Most of the companies that make these things are pretty helpfull, with the exception of mb from what I've read. I've had real good luck with kp at pd and hoyt at gt. I've talked to the boys at gd a couple times with regards to my lil bro's longtail, and they have been helpfull too. Can't recall who to ask for at gd though.
Author:  Country [ Thu Jan 14, 2010 6:12 pm ]
27 and 30 are the same block...I vote yes for easy swap, as long as output same.
Author:  kibb [ Thu Jan 14, 2010 6:34 pm ]
If the outputs are different sizes, get a new half yoke at Tractor Supply.
Author:  GDLT31 [ Sat Jan 16, 2010 2:48 am ]
The 27hp and 30hp Kohler both use 1.125" output shaft.The foot print for the mounting is the same.Go for it.
Author:  JpEater [ Sat Jan 16, 2010 11:32 am ]
I bought an 09 Kohler 30 yesterday for $500. With all that my 27 needed this will be the cheaper route. I am going to put on the 30 and leave it stock. I am afaid I may not like the LT on my boat so I don't want to invest too much into it till I know for sure.
Author:  GeeLeDouche [ Sun Jan 17, 2010 1:30 am ]
thats cool! let us know how it works. :)
Author:  willtodo [ Tue Jan 26, 2010 7:23 pm ]
Coco told me that the 30 would not do well due to a low end tour problem,i was also told the same by MB.
Author:  JpEater [ Tue Jan 26, 2010 9:39 pm ]
Author:  kibb [ Wed Jan 27, 2010 4:54 pm ]
Author:  DuckHunter [ Sat Jan 30, 2010 4:53 pm ]
JP how fast did that 30 push the aucoin hull?
Author:  JpEater [ Sun Jan 31, 2010 9:57 am ]
GPS'd it yesterday. Ran 18 on average with just me at 3400-3450 RPMs. If I reach back and work the throttle manually and bypass the governer the best I got was 22.5 at 3800-3850 RPMS. I want to turn my governer up but not real sure what the safe limit is for a Kohler. Its no speed demon but it will get me by for now.
Author:  willtodo [ Sun Jan 31, 2010 5:22 pm ]
Author:  fishon!! [ Sun Jan 31, 2010 5:57 pm ]
if you do have low end torque problems, you might just be able to adjust the idle screw and have it idle at higher rpms.
don;t qoute me on that, i'd like for someone more carb smart to answer that for me.
Author:  JpEater [ Sun Jan 31, 2010 6:44 pm ]
The only thing that I can see that might cause a bog with the 30 is the lack of accelerator pump on the carb. The 27 has an accelerator pump. But so far I have had no problem with power or how it runs. The only issues I have had are attributed to the 30-40 degree weather I have been running in. Its a little cold natured. Gonna get some more stick time and play as I go.
Author:  willtodo [ Sun Feb 14, 2010 9:28 pm ]
lets get a little more feed back on the 30 vs the 27.
Author:  JpEater [ Mon Feb 15, 2010 8:47 am ]
I am happy with my 30. The only reason I went with it is because I didn't want to spend a ton of money to get my 27 back in shape. I bought the 30 and honed and re-rung it. Runs great now. I am happy with performance. It pushes my boat an average of 18-19mph with a worn out prop. Over all I am very happy with the motor. I want a SD but the LT will get me by for now.
