It is currently Sun Sep 27, 2026 4:48 pm
[ 9 posts ] |
Leaky upper seal/u-joint on go devil..is it leaking to much?
ozarktroutbum
After taking it out and running for maybe 30 mins or so I'm seeing about 1/2 a teaspoon in leakage on the upper seal. Seems like it wasn't doing this 25 hrs ago. Just noticed it.
How long can I run it like this?
Also, this is a 2000 year model. I think I am pumping enough grease (I know the manual says 3/4 full)
| Thu Feb 01, 2018 7:22 pm |
flint87
| Thu Feb 01, 2018 7:37 pm |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
 Re: Leaky upper seal/u-joint on go devil..is it leaking to m
I've let the top go a while, it just makes a mess. I'll change the bottom seals quick if any grease is getting past though.
| Thu Feb 01, 2018 7:43 pm |
flint87
| Thu Feb 01, 2018 7:46 pm |
Will C
On that top sealed bearing that pukes,,, its usally from pumping on that top zert. 1 pump up there once in a while = cool. If you pump more than a few squirts it pushes the seal out of the bearing from pressure buildup between the upper shaft seal and the sealed bearing. I see this over and over. This is assuming you have the newer style roller bearing on it
| Thu Feb 01, 2018 8:40 pm |
flint87
| Thu Feb 01, 2018 9:20 pm |
ozarktroutbum
| Thu Feb 01, 2018 9:44 pm |
Bigbend
I want to say you have the old style, I think the updates were in 2001.
| Fri Feb 02, 2018 3:37 am |
Bigbend
Double post
[ 9 posts ] |
