| Leaky upper seal/u-joint on go devil..is it leaking to much? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=72003 |
| Author: | ozarktroutbum [ Thu Feb 01, 2018 7:22 pm ] |
| Post subject: | Leaky upper seal/u-joint on go devil..is it leaking to much? |
After taking it out and running for maybe 30 mins or so I'm seeing about 1/2 a teaspoon in leakage on the upper seal. Seems like it wasn't doing this 25 hrs ago. Just noticed it. How long can I run it like this? Also, this is a 2000 year model. I think I am pumping enough grease (I know the manual says 3/4 full) |
| Author: | flint87 [ Thu Feb 01, 2018 7:37 pm ] |
| Author: | Bigbend [ Thu Feb 01, 2018 7:43 pm ] |
| Post subject: | Re: Leaky upper seal/u-joint on go devil..is it leaking to m |
I've let the top go a while, it just makes a mess. I'll change the bottom seals quick if any grease is getting past though. |
| Author: | flint87 [ Thu Feb 01, 2018 7:46 pm ] |
| Author: | Will C [ Thu Feb 01, 2018 8:40 pm ] |
On that top sealed bearing that pukes,,, its usally from pumping on that top zert. 1 pump up there once in a while = cool. If you pump more than a few squirts it pushes the seal out of the bearing from pressure buildup between the upper shaft seal and the sealed bearing. I see this over and over. This is assuming you have the newer style roller bearing on it |
| Author: | flint87 [ Thu Feb 01, 2018 9:20 pm ] |
| Author: | ozarktroutbum [ Thu Feb 01, 2018 9:44 pm ] |
| Author: | Bigbend [ Fri Feb 02, 2018 3:37 am ] |
I want to say you have the old style, I think the updates were in 2001. |
Double post |
