It is currently Fri Jan 02, 2026 8:30 am
Reply to topic  [ 12 posts ]
 Longtail advice on a 1546 Xpress
Post Longtail advice on a 1546 Xpress
What motor would be good for my 1546 Xpress mod v had a Prodrive and it didn’t like it so put it on my big boat and now tubing a 25 outboard and thinking bout swapping it for a longtail go devil thinking 23hp or maybe bigger even a 35 longtail will weight less then my Prodrive so know boat could hold it just looking for advice .
Wed Mar 21, 2018 9:30 pm
Post Re: Longtail advice on a 1546 Xpress
I think small block longtail would feel at home on that boat. A 23 copperhead might be real fun on it, but cost more
Wed Mar 21, 2018 11:16 pm
Wouldn’t mine a go devil surface drive really but Thought bout a copperhead never ran one tho even
Thu Mar 22, 2018 8:36 am
The mod V will hurt performance with heavier motors... That is why it runs good
with a 25 outboard but not the PD...
If you are only interested in getting thru the tough stuff but not speed - the 23LT
will push you thru nearly anything and likely work better than the larger LTs...
With 23 LT you will likely get 17mph solo and have trouble getting on plane when
loaded with gear and two guys - but should get you just about anywhere...
Used a similar hull with only 8LT for years on a small lease with good results but
it crawled thru about anything - about 5mph was tops with gear...
Eat - Sleep - Hunt ! ! !
Thu Mar 22, 2018 8:51 am
yea It didn’t like the Prodrive at all I used have longtail didn’t mind it they get job done gota buddy with 23 I may see what it will do before I decide anything forsure just wondered if anyone ran a big block longtail on a boat that small ?
Thu Mar 22, 2018 9:17 am
Why not sell the hull and get a rig that does what you really want?
Thu Mar 22, 2018 10:24 am
Cuase like boat a lot it’s paid for got another one with Prodrive on it just like having a smaller rig for some stuff
Thu Mar 22, 2018 11:24 am
Fri Mar 23, 2018 10:01 am
1648MV SeaArk 37 EFI Backwater SWOMP Lite
Fri Mar 23, 2018 3:56 pm
Fri Mar 23, 2018 4:36 pm
Fri Mar 23, 2018 4:38 pm
And I about didn't but Jake at BW set me straight. I'm REALLY glad I didn't have to take it all back apart and move it outboard
Fri Mar 23, 2018 5:10 pm
