| Shaft movement http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=72385 |
| Author: | Fowl Language [ Sat Apr 28, 2018 4:57 pm ] |
| Post subject: | Shaft movement |
Ran the motor today (35HP with pipes and M-Carb) on a 1760 Lowe. Ran great for an hour, then started hearing a noise. Thought it was the upper seal and then noticed at the dock that the shaft had moved upward about an inch. The movement also pushed the u-joint up on the engine drive shaft an inch. Not sure why. Has anyone seen this and what is the fix? Do I need both upper and lower seals and then reset the shaft? Let me know your thoughts. Thanks, Steve |
| Author: | Will C [ Sun Apr 29, 2018 10:18 am ] |
| Post subject: | Re: Shaft movement |
I don't see how the shaft would move an inch without the prop or prop nut running up against the lower seal retainer. I can believe the joint walking up. This would through the angles off and put it into a major bind. Depending on what actually moved you may be able to move the joint back down into position and lock it in |
| Author: | Fowl Language [ Sun Apr 29, 2018 11:04 am ] |
Thanks Will. The prop nut did move up and is almost touching the lower seal. I'll try to loosen the u-joint and move it back down by hand. I sent you this question at your shop also. Let me know what you think when you read my other question. |
