| Longtail mounting location http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=72589 |
| Author: | Aulee42 [ Mon Jun 18, 2018 8:50 am ] |
| Post subject: | Longtail mounting location |
I have a 1650 custom welded Jon boat. It's true flat bottom and has a 14" hunt deck. My question is should i mount a longtail at the normal transom location or out on the hunt deck? Hunt deck is braced for a transom just need to weld a mounting block on top of hunt deck. Also if I theoretically went with a backwaters LT would having the hunt deck make a difference in which length longtail to get? Sent from my Pixel 2 using Tapatalk |
| Author: | Aulee42 [ Mon Jun 18, 2018 8:52 am ] |
| Post subject: | Re: Longtail mounting location |
| Author: | Aulee42 [ Mon Jun 18, 2018 8:54 am ] |
Boat Sent from my Pixel 2 using Tapatalk |
| Author: | Glades Ranger [ Mon Jun 18, 2018 8:14 pm ] |
Call Backwater for advice! |
| Author: | Ducknut [ Tue Jun 19, 2018 7:04 am ] |
That boat looks to have little to no rake. Seems like it will be tough to plane with a MM. I would get as much weight as far back as possible. $0.02 Good luck |
| Author: | Aulee42 [ Wed Jun 20, 2018 8:56 pm ] |
| Author: | Glades Ranger [ Thu Jun 21, 2018 5:29 pm ] |
Aulee, did you call Backwater yet? I would send them pics, dimensions, etc. to help in deciding on the motor, they have a new 37/40 EFI lite frame models now (225#), you could probably handle that. Honestly, Jake at BW helped me a lot regarding best mounting type for my hull, and you could get his input. They use a 1752 alweld many times with the big blocks. The only question is the best place to mount the motor. Good luck! |
| Author: | Aulee42 [ Thu Jun 21, 2018 8:51 pm ] |
