It is currently Mon Nov 30, 2026 4:35 am
Reply to topic  [ 3 posts ]
 27 Kohler GD problem
Post 27 Kohler GD problem
Help!
27 hp Kohler GD. motor starts and idles and runs wide open fine out of the water. Running full throttle across a lake it starts to bog and dies. When it starts to bog if you pull the choke half way on it will continue to run. Any help appreciated. Thanks. Matt
Tue Jun 19, 2018 4:00 pm
Post Re: 27 Kohler GD problem
Make sure the throttle/choke linkage and stop nuts/bolts are all there. I had a 25 Kohler Go Devil I sold that did the same thing, new owner told me it was missing a stop screw or nut that kept stuff from going beyond it's allotted travel.
Sat Jun 23, 2018 11:06 am
I will check that. Thank you!
Tue Jun 26, 2018 6:34 am
