| u-joint positioning http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=73093 |
| Author: | Fowl Language [ Wed Oct 10, 2018 7:49 am ] |
| Post subject: | u-joint positioning |
So I still have my other LT. MB 35 with M-Carb and pipes. Over all, I have to say it had been a good motor. Since I now have my BW 40, I decided to practice my mechanic skills. Last fall I replaced the magnets and wiring harness. Reset the valve lash. Motor runs great! I moved on the the drive and I'm currently replacing the yokes and u-joint. The drive shaft seems to turn smoothly, so I don't think I need to replace the upper and lower bearings. But since I have it apart, I'm playing with doing it any way. How do you know if the bearings need to be replaced? Back to my question. When positioning the yokes on the engine and drive shaft, are there any words of advise? I find no videos on this and there is no manual with positioning specs. Do you position the yokes on the drive shaft 1st or the engine 1st? |
| Author: | Fowl Language [ Thu Oct 11, 2018 7:43 am ] |
| Post subject: | Re: u-joint positioning |
So no one has replaced a u-joint that could share their experience with positioning? What I have seen is that if it is not positioned correctly you rob yourself of power. |
| Author: | fireman1293 [ Sun Oct 14, 2018 9:01 am ] |
I'll be your huckleberry. With the shaft all the way in there technically should only be one position where the u joint can go. If you think about it and draw a straight line on both shafts, where they intersect is where your cross section of your u joint should rest. If its too far either way the yokes would not sit square on the shaft and would be in a bind. How this helps. I do like to put my set screws on the opposite sides to sort of balance the joint as a whole. Good luck |
| Author: | Russ [ Sun Oct 14, 2018 10:39 am ] |
I would put the yoke on the prop shaft first, because you can always unbolt the engine if needed to get that yoke on. Been 12 years since we've done it, but don't figure there would be a huge issue doing it that way if you couldn't get it wedged in otherwise. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | nuccifish06 [ Mon Oct 15, 2018 10:45 am ] |
Make sure to mark everything after you tighten it down and do short test runs to make sure nothing moves. I've had to drill holes into the prop shaft and motor shaft to have a solid set because the prop shaft moved itself up and destroyed itself and upper bushings on a gdlt. Sent from my Moto Z (2) using Tapatalk |
| Author: | Fowl Language [ Sat Oct 20, 2018 8:30 pm ] |
Just back on here. Thank you for your thoughts. I did end up putting the yoke on the shaft 1st. I then swung the motor in place and slid it in together. Tightened all bolts to secure the motor. There was still a little play before I set the screws, so I tapped the shaft up so the yokes were snug. I did make the key way a little longer on both, especially the motor shaft. My issue before was that it was tight on the shaft, but sliding up on the motor. I reconnected all wires and the motor turned over. I'll be getting some new gas and fuel line in the morning and will let it run. I'll then re-set the screws with some semi permanent loctite. I'll let you know how it goes. |
