| 20hp Honda bogs down under load. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=73135 |
| Author: | Jpl00311 [ Sat Oct 20, 2018 9:49 am ] |
| Post subject: | 20hp Honda bogs down under load. |
I have Gx620 on go devel frame. Motor runs good idles good when prop is out the water. Bogs down when I put in water. New carb, fuel pump, fuel filter, new hose. Looks to be getting food fire from both spark plugs. What all think? |
| Author: | aknative [ Fri Oct 26, 2018 8:38 pm ] |
| Post subject: | Re: 20hp Honda bogs down under load. |
Is it over propped? I had a 25 Kohler, a stop nut came loose somewhere and when I went to give it full throttle it would activate the choke and bog it down. |
| Author: | Russ [ Mon Oct 29, 2018 9:10 pm ] |
Check the oil. Those things don't like too much oil. Other than that, likely culprit is simple, and carb related. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | WI715 [ Tue Oct 30, 2018 4:12 am ] |
Try to keep the bulb primed by hand every few seconds to see if that helps. I replaced the fuel pump, carb, and filter on my gx clone but it starve itself out of fuel after idling for a minute or under load. I put a low pressure electric fuel pump on, that solved my issue Sent from my SM-G950U using Tapatalk |
