It is currently Wed Sep 02, 2026 6:51 am
Reply to topic  [ 3 posts ]
 Shimming a BW 40
Post Shimming a BW 40
Been having fun with the new 40. Season started and it has been great.
I did notice the other day that if I push down on the handle to move the cavatation plate upward, I immediately pick up rpms and about 2 mph.
So, I figured a shim might help.
I installed one and it helped some, but when I pushed down on the handle, again I picked up rpms and speed.
So I thought I would add 2 shims.
Before I did, I look at the cavatation plate, it extends beyond the the prop about an inch, maybe a little longer.
When I added a 2nd shim, the plate moved upward on the drive tube and the the prop was even with the edge of the plate and maybe a little beyond.
Would this be an issue? Has any one added 2 shims? How did the 40 perform?
On a side note, what rmps are you getting with a loaded boat. I'm running 3900 to 4100. Wondered what others are getting.
Tue Nov 20, 2018 7:34 pm
Post Re: Shimming a BW 40
I get between 4100 and 4300rpm loaded
Wed Nov 21, 2018 4:34 am
I think I have it dialed in.
Runs right at the surface.
4250 RPMs.
1st time I have ever been able to run a longtail sitting down..
Fri Nov 23, 2018 5:27 pm
