Shimming a BW 40
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=73251
Author:  Fowl Language [ Tue Nov 20, 2018 7:34 pm ]
Post subject:  Shimming a BW 40
Been having fun with the new 40. Season started and it has been great.
I did notice the other day that if I push down on the handle to move the cavatation plate upward, I immediately pick up rpms and about 2 mph.
So, I figured a shim might help.
I installed one and it helped some, but when I pushed down on the handle, again I picked up rpms and speed.
So I thought I would add 2 shims.
Before I did, I look at the cavatation plate, it extends beyond the the prop about an inch, maybe a little longer.
When I added a 2nd shim, the plate moved upward on the drive tube and the the prop was even with the edge of the plate and maybe a little beyond.
Would this be an issue? Has any one added 2 shims? How did the 40 perform?
On a side note, what rmps are you getting with a loaded boat. I'm running 3900 to 4100. Wondered what others are getting.
Author:  mnugent [ Wed Nov 21, 2018 4:34 am ]
Post subject:  Re: Shimming a BW 40
I get between 4100 and 4300rpm loaded
Author:  Fowl Language [ Fri Nov 23, 2018 5:27 pm ]
I think I have it dialed in.
Runs right at the surface.
4250 RPMs.
1st time I have ever been able to run a longtail sitting down..
