| Hunt deck with longtail?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=73319 |
| Author: | MNGunner [ Sat Dec 08, 2018 6:58 pm ] |
| Post subject: | Hunt deck with longtail?? |
I saw some threads on this. Some seem to hint that it could be problematic to put a longtail on a hunt deck (then devolved into pods vs huntdeck). Why would that be? Is there any issues with just putting a longtail on a boat with a huntdeck as you would with a surface drive? I see some guys that had a hunt deck but then mounted the motor to the "interior" transom (false transom). Why? Is there something I'm missing like it makes turning harder or something? |
| Author: | Russ [ Sat Dec 08, 2018 7:36 pm ] |
| Post subject: | Re: Hunt deck with longtail?? |
Just recently put a longtail on mine with a huntdeck. It's fine. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | forresj [ Mon Dec 10, 2018 7:15 am ] |
The only negative I can think of is maybe not being able to swing the tail into the boat and put it into a skeg holder for transport but that might not even be a problem |
| Author: | MNGunner [ Mon Dec 10, 2018 7:38 am ] |
| Author: | Russ [ Mon Dec 10, 2018 9:44 am ] |
I can spin mine around, but it's a big block, so the handle sticks way out the back and because of the false transom it angles the handle downward more than I want. I just hang flagging on my prop and skeg and leave it facing normal. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Russ [ Mon Dec 10, 2018 9:46 am ] |
Oh, and operation is fine. No issues at all. Im not too close to the false transom when running it standing up, and I can sit down and run it in deep water because my half box is farther forward than if I didn't have the hunt deck or if I mounted on the false transom. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | MNGunner [ Fri Dec 14, 2018 7:35 am ] |
Thanks for the replies, Russ. |
| Author: | WI715 [ Sun Dec 30, 2018 4:18 pm ] |
I have a LT on my huntdeck. This is the only picture I have on my phone but I did have to get my false transom so everything would work right. Sent from my SM-G950U using Tapatalk |
| Author: | MNGunner [ Mon Dec 31, 2018 10:28 am ] |
| Author: | Russ [ Mon Dec 31, 2018 12:30 pm ] |
It looks like it's mounted on the transom, he just had to get the false transom cut down some. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | MNGunner [ Tue Jan 01, 2019 10:19 am ] |
| Author: | Russ [ Tue Jan 01, 2019 10:49 am ] |
Some false transoms will be too high, some fine. Mine could stand to be a couple inches lower or the transom where the motor mounts a couple inches higher, but it works for my needs fine. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | WI715 [ Thu Jan 03, 2019 5:43 pm ] |
I'm not sure how to get notifications on this. But yall got it sorted out. Next boat will have a 2' huntdeck which would eliminate the issue Sent from my SM-G950U using Tapatalk |
| Author: | WI715 [ Thu Jan 03, 2019 5:47 pm ] |
Ignore the mess but here's the set up Sent from my SM-G950U using Tapatalk |
