| New to me longtail http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=74619 |
| Author: | Unclejess1221 [ Sat Oct 12, 2019 4:17 pm ] |
| Post subject: | New to me longtail |
Purchased a homemade setup from a guy for couple hundred bucks. He said it runs but had a vibration issue that he couldn’t figure out. After disassembling the housing I found no evidence of a center bushing which I’m 99% sure that’s the vibration he was talking about. Unfortunately whoever originally built this setup used 1” black pipe threaded on both ends and milled out each end to accept a 1” bronze bushing. Only looks to be milled out 1/16” or so. I ordered 2 15/16od bushings and installed. Had to sand the bushings down quite a bit to get one inside the outer housing due to a seam that runs the whole length of the pipe. After lining everything up I welded a nut to the outer housing in hopes to pinch the new bushing in place and managed to split the bushing as soon as I tightened the set screw. Also when testing the setup without the center bushing the u joint howls sounds like its toast too. Or there’s an alignment problem somewhere. Debating on scraping the setup and just ordering a kit online. Any insight or opinions are appreciated. |
| Author: | GDLT31 [ Sun Apr 19, 2020 10:30 am ] |
| Post subject: | Re: New to me longtail |
From what I see is the angle is a little much ( photo upside down ) or even a bent shaft. The center bushing might help. I have a long tail 31 go devil and I hit a rock and bent the end where the prop is mounted and there were vibrations were very slight but there. Replaced shaft problem fixed. |
