It is currently Sun Oct 25, 2026 3:11 pm
Reply to topic  [ 11 posts ]
 Which boat Jon boat or wood skiff
Post Which boat Jon boat or wood skiff
I have backwater gx690 on order. I have 2 older boats to choose from. A wooden 1644 skiff or a 1636 aluminum boat.
Both need a little work. Used in soft muddy marsh. No trees or rocks to be concerned. Which would you choose and why? First post and gonna be first mud motor.
Tue Nov 26, 2019 7:12 am
Post Re: Which boat Jon boat or wood skiff
Yes. The answer is yes.
You'd likely get better performance out of the aluminum boat given it's narrower hull and possibly being a lighter boat. If they're similar in weight, and using the same motor, I think the wooden boat being bigger, though it may be slower empty, will lose less speed when carrying the same load as the aluminum boat...maybe. I know that I can push my 1848 faster empty than I can the 2448, but the 2448 takes more to bog down.
I'd use whichever one is easier to make useable by the time the motor arrives. Then, when I wasn't playing in that one I'd work on the other, and when it's ready try it as well. If you do that, let us know what you find.
Wed Nov 27, 2019 9:11 pm
Use the aluminum. Not enough difference between the 2 in base size for the 44 to be that much better, but the aluminum carries that width farther forward. Itll do better with a small longtail, and likely be a bit lighter than that wooden boat (dunno about the weight for sure, though).
#GhostBoat
#Whoneedsphysicsihaveamudmotor
Wed Nov 27, 2019 9:59 pm
Btw, that is gonna be a lot of motor for a boat that narrow. I've had that same engine on a 1546 and a 1442. Turning is gonna be entertaining for anyone not in the boat with you, and squirrelly with this being your first longtail. Dont get in a hurry to get places, and learn how to run it safely. Be careful and wear your kill switch and life jacket. And dont go in big water, ever, with that thing.
Enjoy it, itll be a good rig. Just know it has some limitations and you'll have a lot of fun.
#GhostBoat
Wed Nov 27, 2019 10:03 pm
Thanks for responses. I’m leaning towards the wood because I think it would be safer. Little wider and taller sides. Anyone ever had a mm on a wooden skiff? Thanks fellas.
Thu Nov 28, 2019 5:49 am
Decided on wooden skiff. Found a little rot. Gonna repair hopefully next week. Boat is heavier than I remember easily 350 lbs I guess. Any ideas on speed? How should she handle? Thanks
Sat Nov 30, 2019 3:51 pm
Making progress. Fixed rot, working on painting. Motor is ready to install next. Any guesses on top speed. Anyone with mud motor on wooden skiff? Thanks
Tue Dec 10, 2019 4:03 pm
This is the boat I built. Fiberglass over wood. I run a 13 longtail that I built as well. Not a speed demon by any means but it’ll goes in the shallow dang good. The frogs, fish ducks and deer are all feeling it’s effects this year
Tue Dec 10, 2019 5:34 pm
Almost ready for the water. How it is now I can not rotate prop end all the way around into the boat. I can raise it slightly with the mount(it might not be enough to get over sides). I was concerned raising it up would affect strength and or performance. Is that true? Also what are reasons for wanting to swing motor all the way around. Thanks.
Wed Jan 01, 2020 3:42 pm
So you dont have a 6 ft bumper attractant sticking out behind your boat. Get a flag for it.
#GhostBoat
Wed Jan 01, 2020 4:32 pm
Get a flag for it. If you shim it up to be able to swing into the boat, it will affect performance by changing where the prop is running. If you only needed like an inch, or something small to clear the corner of the boat it might be worth it. A small change like that could probably be corrected with messing with the cavitation plate. If it’s running really good now I’d leave it alone.
Thu Jan 02, 2020 2:57 am
